Installing PowerBook G4 Titanium DVI PRAM Battery
  • Author: iRobot
  • Difficulty: Moderate
  • Add Note x
  • x 6
The time and date, as well as other settings, are kept by the PRAM battery when your machine is off.
Sections
Files
first image
thumb image 1
thumb image 2
  • Locate the battery release tab on the underside of the G4.
  • Slide the battery release tab to the left and lift the battery out of the computer.
first image
Add Note Edit Step 2 — Lower Case  ¶
  • Remove the seven T8 Torx screws from the lower case.
first image
Add Note Edit Step 3  ¶
  • Using your thumbs, slide the lower case away from you.
  • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
  • Lift the lower case off.
Next » « Previous
