Installing PowerBook G4 Titanium DVI Modem
  • Author: iRobot
  • Difficulty: Moderate
  • Add Note x
The 56k internal modem is attached to the optical drive and standard on all models.
Sections
first image
thumb image 1
thumb image 2
  • Locate the battery release tab on the underside of the G4.
  • Slide the battery release tab to the left and lift the battery out of the computer.
first image
Add Note Edit Step 2 — Lower Case  ¶
  • Remove the seven T8 Torx screws from the lower case.
first image
Add Note Edit Step 3  ¶
  • Using your thumbs, slide the lower case away from you.
  • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
  • Lift the lower case off.
first image
Add Note Edit Step 4  ¶
  • Your laptop should look approximately like this.
first image
Add Note Edit Step 5 — Airport Card  ¶
  • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
  • Disconnect the antenna cable from the left side of the Airport card.
first image
Add Note Edit Step 6 — Hard Drive  ¶
  • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
first image
Add Note Edit Step 7  ¶
  • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
first image
Add Note Edit Step 8  ¶
  • Remove the hard drive by lifting the left edge up and out of the computer.
  • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
first image
Add Note Edit Step 9  ¶
first image
Add Note Edit Step 10 — Optical Drive Removal  ¶
  • Disconnect and remove the indicated orange ribbon cable.
first image
Add Note Edit Step 11  ¶
  • Disconnect the pink and white inverter cable from the inverter board.
  • The display inverter has orange plastic shielding around it that looks similar to the tape used elsewhere within the computer. Do not remove the shielding from the inverter.
first image
Add Note Edit Step 12  ¶
  • Remove the two silver T8 Torx screws from the black plastic bar.
  • Lift the black plastic bar out.
  • Reassembly will be significantly easier if you reseat the hard drive before returning the black bar to its place.
first image
Add Note Edit Step 13  ¶
  • Disconnect the two orange connectors from the logic board, removing tape as necessary.
first image
Add Note Edit Step 14  ¶
  • Lift the drive up on the right side so that you can access and disconnect the modem cable and inverter cable.
first image
Add Note Edit Step 15  ¶
  • Remove the drive by lifting the right edge up and out of the computer.
first image
Add Note Edit Step 16 — Modem  ¶
  • Remove the two T6 Torx screws from the modem.
  • Lift the modem off the optical drive, carefully guiding the orange ribbon cable through the space in the drive mount.
For more information, check out the PowerBook G4 Titanium DVI device page.
Did you successfully follow this guide?
This guide has been completed 0 times.
