Page 1 of 1
Installing PowerBook G4 Titanium DVI Logic Board
- Author: iRobot
- Difficulty: Difficult
The motherboard - which includes all ports but not the DC-In board - is fairly easy to change.
Sections
- Battery 1 step
- Keyboard 3 steps
- RAM 1 step
- Lower Case 3 steps
- Airport Card 1 step
- Hard Drive 4 steps
- Optical Drive Removal 6 steps
- DC-In Board 3 steps
- Modem Filter Board 5 steps
- Logic Board 4 steps
- View:
- Paginated
- Full width
Edit
Step 2
Keyboard
Turn the keyboard locking screw located in the middle of the keyboard so that it is parallel to the space bar. A half turn from parallel to parallel will unlock it. Another half turn will lock it again.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Edit
Step 22
Lift the DC-In board out of the computer by pulling up and away from you.
If you don't have a 667 MHz computer, there is a fan in this location which makes it a bit difficult to remove the DC-In board.
If there is a fan present, rotate the DC-In board slightly clockwise before easing it out at a slight angle in order to clear the fan clamp on top of it.
Edit
Step 23
Modem Filter Board
Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over and place it on the cloth.
Disconnect the four indicated connectors from the logic board.
The large multicolor cable may be difficult to free.
The top center cable may not need to be disconnected to remove the modem filter board. It connects to the logic board fan to its immediate left, which is attached to the logic board itself.
Edit
Step 30
Carefully lift the logic board up and pull it away from you.
This step requires some force, but if the logic board will not come up, make sure that you have removed all the necessary screws and connectors. Warming the heatsink with a heatgun or blow dryer will help release the logic board.
On 800 MHz and above G4s, you must disconnect the fan cable from the logic board before you lift the board entirely off.
This guide has been completed 11 times.
Page 1 of 1
