Installing PowerBook G4 Titanium DVI Latch
  • Author: iRobot
  • Difficulty: Moderate
  • Add Note x
Latch mechanism located in the upper case.
Sections
Files
first image
thumb image 1
thumb image 2
  • Locate the battery release tab on the underside of the G4.
  • Slide the battery release tab to the left and lift the battery out of the computer.
first image
Add Note Edit Step 2 — Lower Case  ¶
  • Remove the seven T8 Torx screws from the lower case.
first image
Add Note Edit Step 3  ¶
  • Using your thumbs, slide the lower case away from you.
  • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
  • Lift the lower case off.
first image
Add Note Edit Step 4  ¶
  • Your laptop should look approximately like this.
first image
Add Note Edit Step 5 — Hard Drive  ¶
  • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
first image
Add Note Edit Step 6  ¶
  • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
first image
Add Note Edit Step 7  ¶
  • Remove the hard drive by lifting the left edge up and out of the computer.
  • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
first image
Add Note Edit Step 8  ¶
first image
Add Note Edit Step 9 — Latch  ¶
  • Use your thumbnails to push in and then lift the two fingers of the latch clip over the restraining bar.
first image
Add Note Edit Step 10  ¶
  • Now use your index fingers' nails to pull at the "elbows" of the clip, rotating it upward approximately 90 degrees, or until the latch pops out
first image
Add Note Edit Step 11  ¶
  • Insert the new latch by rotating the clip up and pushing the latch into place. Then rotate the clip back down, pushing in at the area where the clip bends around the latch. Make sure to insert the clip fingers back into their slots.
For more information, check out the PowerBook G4 Titanium DVI device page.
Did you successfully follow this guide?
This guide has been completed 0 times.
