Installing PowerBook G4 Titanium DVI Inverter
The inverter powers the LCD backlight and is not a difficult part to replace.
Author:
iRobot Difficulty: Moderate
Embed this guide With the HTML code below, you can embed this guide as a small widget on your website.
Files Tools Relevant parts
Edit Step 2
Lower Case
Using your thumbs, slide the lower case away from you.
The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
Lift the lower case off.
Edit Step 5
Hard Drive
Remove the hard drive by lifting the left edge up and out of the computer.
There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
Edit Step 9
Optical Drive Removal
Disconnect the pink and white inverter cable from the inverter board.
The display inverter has orange plastic shielding around it that looks similar to the tape used elsewhere within the computer. Do not remove the shielding from the inverter.
Remove the two silver T8 Torx screws from the black plastic bar.
Lift the black plastic bar out.
Reassembly will be significantly easier if you reseat the hard drive before returning the black bar to its place.
Edit Step 15
Modem
Remove the two T6 Torx screws from the modem.
Lift the modem off the optical drive, carefully guiding the orange ribbon cable through the space in the drive mount.
Edit Step 16
Inverter
For more information, check out the PowerBook G4 Titanium DVI
device page .
Fantastic! Great work!
Your profile has been updated to show that you completed Installing PowerBook G4 Titanium DVI Inverter. Change your mind? Oops, I actually didn't do it.
Did you successfully follow this guide? I did it! Success!
This guide has been completed 6 times.
