first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4 — RAM  ¶
  • Use your fingertips to pull the two RAM arms away from the sides of the RAM chip. The chip should pop up slightly.
  • Pull the RAM chip away from its socket and remove it from the logic board.
  • Repeat this process for the other RAM chip, if present.
Next » « Previous
For more information, check out the PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) device page.
Did you successfully follow this guide?
This guide has been completed 8 times.
