Installing PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PRAM Battery & USB Board
  • Add Note x
  • x 3
Replace your PRAM battery & USB board to preserve date and time after system shutdowns and to fix an unresponsive front USB port.
first image
thumb image 1
thumb image 2
  • Use your thumbs to push the two battery retaining tabs away from the battery.
  • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
first image
Add Note Edit Step 2 — Memory Door  ¶
  • Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
Next » « Previous
