Page 1 of 1
Installing PowerBook G4 Aluminum 17" 1-1.67 GHz LCD
- Author: Andrew Bookholt
- Difficulty: Difficult
Use this guide to save money by replacing only the LCD, not the entire display.
Tools (continued)
Relevant parts
- View:
- Paginated
- Full width
Edit
Step 1
Rear Display Bezel
Remove the single Phillips screw near the lower left and right corners of the display.
Removing these two screws may be difficult. It is helpful to open the display as much as possible for clearance to use a screwdriver. Also, a combination of #00 Phillips and small flathead screwdrivers along with a pair of tweezers may aid in removal.
Edit
Step 2
The picture at left (rear panel already removed) shows the locations of the metal clips (shown in red) that snap on to the front display bezel. In the next few steps, you will use a small flathead screwdriver to release these clips from a ridge around the perimeter of the front display bezel.
When prying in the following steps, be sure not to damage the antenna cables that run around the perimeter of the front display bezel.
Edit
Step 3
Insert the flat end of a spudger between the rear display bezel and the plastic rim attached to the front display bezel near the lower right corner of the display.
Do not try to insert the spudger between the front display bezel and its plastic surround.
While carefully prying the rear display bezel away from the display assembly, use a small flathead screwdriver to pry the small steel clip nearest the bottom right corner of the display away from the edge of the front display bezel.
Repeat the above procedure until you've released all the clips along the right side of the display.
Edit
Step 5
Insert the flat end of a spudger between the rear display bezel and the plastic surround of the front display bezel near the lower left corner of the display.
Carefully pry the rear display bezel away from the front display bezel to expose the metal clips along the left side of the display.
Repeat the previous procedure to release the clips along the left side of the rear display bezel.
Edit
Step 7
Display Inverter
If necessary, remove the tape covering the display inverter.
Carefully lift the display inverter board from the side nearest the display data cable connector.
The display inverter is an extremely thin circuit board that is easily broken. Do not excessively bend or twist it during removal.
Edit
Step 23
In the following steps, you will use a heat gun to soften the adhesive securing the metal LCD frame to the front display bezel. Heat guns have the capability of producing an extremely hot jet of air, so be sure not to overheat the LCD panel.
With the heat gun set to low, start by heating the front display bezel near the upper left corner of the display panel.
Edit
Step 24
Insert a plastic opening tool between the metal LCD frame and the front bezel.
Be sure you are prying between the metal LCD frame and the front bezel, not between the metal LCD frame and the LCD.
It may be necessary to reheat this area until the adhesive yields enough to insert the edge of a tool.
Use the flat end of a metal spudger to gently pry up the adhesive securing the metal LCD frame to the front bezel, taking special care not to scratch the LCD panel.
Edit
Step 25
While it is still inserted between the metal LCD frame and the front bezel, run the edge of your metal spudger along the top edge of the display to separate the adhesive securing the two pieces together, heating the area you are working on with a heat gun as necessary.
If the adhesive is hard to separate, use a heat gun to lightly heat the area you are working on.
This guide has been completed 0 times.
Page 1 of 1
