Page 1 of 1
Installing PowerBook G4 Aluminum 17" 1-1.67 GHz DC-In Board
- Author: iRobot
- Difficulty: Moderate
Tripped over your power cord? At least you don't have to replace the entire logic board.
Tools (continued)
Relevant parts
- View:
- Paginated
- Full width
Edit Step 5 ¶
This is a diagram of the trackpad ribbon clamp connector you will disconnect in the next step.
1) With your fingernails, grasp the locking bar on either side slide it a small amount (about 1/16" or 2 mm) towards the battery.
2) After disengaging the locking bar, slide the cable out of the connector.
Edit Step 6 ¶
For this step, you only need to move the connector about 2 mm. Pulling too hard or too far will damage the connector.
Loosen the trackpad connector by pulling the locking bar toward the battery housing, using the tips of your fingers.
Slide the trackpad cable out of the loosened connector.
When reattaching the trackpad ribbon cable, make sure that the orange cable is slid into the connector above the locking bar.
Note: When reassembling the case, the trackpad cable can get stuck below the slot to the motherboard. It's possible to nudge it out slowly by gently prodding it on either side with a small screwdriver. You don't need to use much force to do this. Eventually it will just pop back out and you can reconnect as per the instructions above. Also, note that the locking bar comes loose so if you see a little piece of plastic lying around when reassembling, that's what it is. :)
Edit Step 7 ¶
Remove the following 10 screws from the bottom case:
Three 1.7 mm Phillips from the front edge of the battery compartment.
One 3.9 mm T8 Torx to the right of the memory card.
One 6.9 mm T8 Torx at the left edge of the memory compartment.
Three 12.4 mm fully threaded Phillips from the center of the row of screws along the back edge of the case.
Two 15.1 mm 2.5 mm threaded Phillips, one from either end of the row of screws along the back edge of the case.
This guide has been completed 14 times.
Page 1 of 1
