Installing PowerBook G4 Aluminum 15" 1.67 GHz Right Clutch Hinge
Replace the right clutch hinge on your PowerBook G4 Aluminum 15" 1.67 GHz.
  • Add Note x
Replace a broken clutch hinge to make your display open silky smooth.
Sections
first image
  • Use a coin to turn the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
first image
Add Note Edit Step 2 — Upper Case  ¶
  • Remove the following 10 screws:
    • Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
    • Four 3 mm Phillips around the memory compartment.
    • Four 16 mm Phillips along the hinge.
first image
Add Note Edit Step 3  ¶
  • Remove the memory compartment cover.
  • Remove the two 12 mm Phillips screws on the Aluminum bracket at the top of the memory compartment.
Next » « Previous
