Page 1 of 1
Installing PowerBook G4 Aluminum 15" 1.67 GHz Lower Case
- Author: Andrew Bookholt
- Difficulty: Difficult
This guide will show you how to remove the lower case from your PowerBook.
Sections
- Battery 1 step
- Upper Case 9 steps
- Right Speaker 3 steps
- Logic Board 7 steps
- Heat Sink & Fans 8 steps
- Lower Case 11 steps
Files
Tools
Tools (continued)
- Arctic Silver Thermal Paste
- Coin
- Phillips #00 Screwdriver
- Spudger
- T6 Torx Screwdriver
- T8 Torx Screwdriver
Relevant parts
- View:
- Paginated
- Full width
Edit
Step 4
Rotate the computer 90 degrees clockwise so the power receptacle faces you.
Remove the three 3 mm Phillips screws along the edge of the lower case.
When replacing these screws, you must install them in the correct order. Begin by installing the screw closest to the display hinge, then work your way toward the front of the computer.
Edit
Step 6
Rotate the computer 90 degrees clockwise so the ports face you.
When replacing these screws, you must install them in the correct order. Begin by installing the screw closest to the display hinge, then work your way toward the front of the computer. Also, be careful not to put the screws in the two holes on either side of the video out port.
Edit
Step 8
Grasp the back corners of the upper case and pull up.
Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
Edit
Step 13
Disconnect the hard drive and optical drive connectors from the logic board.
Disconnect the right speaker cable connector.
De-route the right speaker cable and remove the speaker from the computer.
The right speaker cable may be trapped under the hard drive cable connector. If this is the case, the hard drive will have to be removed in order to de-route the cable and remove the right speaker.
Edit
Step 19
Very gently lift up the left side of the logic board.
If the logic board does not immediately come free, it may be necessary to soften the thermal paste between the logic board and heat sink. You can soften the thermal compound using a hairdryer. Move the hairdryer back and forth between the two fans about one inch above the logic board for one minute. At this point, the logic board should now come free easily.
Lift the left edge of the board up to approximately a 30 degree angle (if you don't have your protractor handy, just lift until the DVI port clears the right hinge).
Once the logic board clears the ports, slide it out to the left.
Edit
Step 20
Important! When you reinstall a logic board, you'll need to replace the thermal paste that goes between the processor on the logic board and the heat sink. Failure to remove the old paste and apply a new layer can cause the computer to overheat and sustain damage. The following steps refer to replacing the thermal paste between the processor and heat sink; follow these steps only when you are ready to place the logic board in the computer.
Use a firm plastic edge to scrape the thermal material off the heat sink.
Apply a new layer of thermal paste to the heat sink.
The PC Card cage needs to be removed before installing your new logic board. The modem cable runs from the modem to the logic board, but connects to the modem underneath the PC Card Cage. After removing the PC card cage, you will need to disconnect the modem cable from the modem, plug it into the bottom of the logic board, and then plug it back into the modem. The PC Card cage can then be reinstalled by following the instructions backwards.
Edit
Step 24
Support the display with one hand as you remove the remaining T8 screws.
Remove the two T8 Torx screws from each side of the display (highlighted in red boxes).
When replacing the display, make sure that the right screw pins down the ground loop from the display data cable.
Disconnect the two antenna cables from the airport/bluetooth card (shown in yellow circles) and deroute them from under the other cabling.
This guide has been completed 2 times.
Page 1 of 1
