Installing PowerBook G4 Aluminum 15" 1.67 GHz Lower Case
  • Add Note x
This guide will show you how to remove the lower case from your PowerBook.
first image
  • Use a coin to turn the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
first image
Add Note Edit Step 2 — Upper Case  ¶
  • Remove the following 10 screws:
    • Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
    • Four 3 mm Phillips around the memory compartment.
    • Four 16 mm Phillips along the hinge.
first image
Add Note Edit Step 3  ¶
  • Remove the memory compartment cover.
  • Remove the two 12 mm Phillips screws on the Aluminum bracket at the top of the memory compartment.
first image
Add Note Edit Step 4  ¶
  • Rotate the computer 90 degrees clockwise so the power receptacle faces you.
  • Remove the three 3 mm Phillips screws along the edge of the lower case.
  • When replacing these screws, you must install them in the correct order. Begin by installing the screw closest to the display hinge, then work your way toward the front of the computer.
first image
Add Note Edit Step 5  ¶
  • Turn the computer 90 degrees clockwise so the hinge faces you.
  • Remove the lower 5 mm Phillips screw on each side of the hinge (two total).
first image
Add Note Edit Step 6  ¶
  • Rotate the computer 90 degrees clockwise so the ports face you.
  • When replacing these screws, you must install them in the correct order. Begin by installing the screw closest to the display hinge, then work your way toward the front of the computer. Also, be careful not to put the screws in the two holes on either side of the video out port.
first image
Add Note Edit Step 7  ¶
  • Turn the computer over and open the display.
  • Remove the two 4.2 mm long, 1.5 mm hex screws at the top corners of the upper case (two total).
  • A T6 Torx driver will work, but repeated use will strip the screws.
first image
Add Note Edit Step 8  ¶
  • Grasp the back corners of the upper case and pull up.
    • Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
  • Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
first image
Add Note Edit Step 9  ¶
  • Rotate the upper case up and toward the screen, so that the upper case rests against it.
first image
Add Note Edit Step 10  ¶
  • Remove the amber tape securing the trackpad ribbon to the logic board.
  • Disconnect the trackpad ribbon from the logic board by pulling up on the connector.
  • Remove the upper case from the computer.
first image
Add Note Edit Step 11 — Right Speaker  ¶
  • Remove the 12 mm Phillips screw holding the right speaker assembly to the lower case.
first image
Add Note Edit Step 12  ¶
  • Use a spudger to gently pry the speaker out of its housing.
  • The right ambient light sensor cover is connected to the speaker and should not be removed.
first image
thumb image 1
thumb image 2
Add Note Edit Step 13  ¶
  • Disconnect the hard drive and optical drive connectors from the logic board.
  • Disconnect the right speaker cable connector.
  • De-route the right speaker cable and remove the speaker from the computer.
  • The right speaker cable may be trapped under the hard drive cable connector. If this is the case, the hard drive will have to be removed in order to de-route the cable and remove the right speaker.
first image
Add Note Edit Step 14 — Logic Board  ¶
  • Disconnect the 11 remaining cable connectors, removing tape as necessary.
  • Some red boxes include two cable connectors.
first image
Add Note Edit Step 15  ¶
  • Remove the following 9 Phillips screws from the logic board:
    • Three 6.5 mm in the upper left corner.
    • Six remaining 4.5 mm.
first image
Add Note Edit Step 16  ¶
  • Lift up the left side of the logic board enough to disconnect the black and red power cable from the left side of the logic board.
  • While the logic board is lifted, also disconnect the battery connector.
first image
thumb image 1
thumb image 2
Add Note Edit Step 17  ¶
  • Remove the single black Phillips screw from the top of the left speaker housing.
  • Remove the 4 mm hex nut from the left speaker housing.
  • Lift the left speaker housing from the lower case and disconnect the microphone/speaker connector.
first image
Add Note Edit Step 18  ¶
  • Lift the left side of the logic board and disconnect the modem cable from the underside of the logic board. A spudger is useful for freeing the connector from its adhesive.
first image
Add Note Edit Step 19  ¶
  • Very gently lift up the left side of the logic board.
  • If the logic board does not immediately come free, it may be necessary to soften the thermal paste between the logic board and heat sink. You can soften the thermal compound using a hairdryer. Move the hairdryer back and forth between the two fans about one inch above the logic board for one minute. At this point, the logic board should now come free easily.
  • Lift the left edge of the board up to approximately a 30 degree angle (if you don't have your protractor handy, just lift until the DVI port clears the right hinge).
  • Once the logic board clears the ports, slide it out to the left.
first image
Add Note Edit Step 20  ¶
  • Important! When you reinstall a logic board, you'll need to replace the thermal paste that goes between the processor on the logic board and the heat sink. Failure to remove the old paste and apply a new layer can cause the computer to overheat and sustain damage. The following steps refer to replacing the thermal paste between the processor and heat sink; follow these steps only when you are ready to place the logic board in the computer.
    • Use a firm plastic edge to scrape the thermal material off the heat sink.
    • Apply a new layer of thermal paste to the heat sink.
  • The PC Card cage needs to be removed before installing your new logic board. The modem cable runs from the modem to the logic board, but connects to the modem underneath the PC Card Cage. After removing the PC card cage, you will need to disconnect the modem cable from the modem, plug it into the bottom of the logic board, and then plug it back into the modem. The PC Card cage can then be reinstalled by following the instructions backwards.
first image
Add Note Edit Step 21 — Heat Sink & Fans  ¶
  • Remove the four Phillips screws from the PC card cage.
  • The two longer screws go on the right side of the card cage.
first image
Add Note Edit Step 22  ¶
  • Lift the PC card cage up and remove it from the computer.
  • When replacing the PC card cage, make sure you attach it to the post on the metal eject button.
first image
Add Note Edit Step 23  ¶
  • Close the display and turn the hinge side of the computer to face you.
  • Remove the remaining Phillips screws on either side of the hinge (two screws total).
first image
Add Note Edit Step 24  ¶
  • Support the display with one hand as you remove the remaining T8 screws.
  • Remove the two T8 Torx screws from each side of the display (highlighted in red boxes).
  • When replacing the display, make sure that the right screw pins down the ground loop from the display data cable.
  • Disconnect the two antenna cables from the airport/bluetooth card (shown in yellow circles) and deroute them from under the other cabling.
first image
Add Note Edit Step 25  ¶
  • Lift the display off the lower case.
first image
Add Note Edit Step 26  ¶
  • Remove the black and silver Phillips screws (two total) holding the right speaker housing to the lower case.
  • Remove the right speaker housing from the lower case.
first image
Add Note Edit Step 27  ¶
  • Remove the following 6 screws:
    • One 9 mm Phillips.
    • Two black 5 mm Phillips.
    • Three silver 4 mm Phillips.
first image
Add Note Edit Step 28  ¶
  • Lift the heat sink and fans out of the lower case.
first image
Add Note Edit Step 29 — Lower Case  ¶
  • Remove the three Phillips screws from the hard drive/optical drive retaining bracket.
  • Remove the short black Phillips screw from the front right corner of the optical drive.
first image
Add Note Edit Step 30  ¶
  • Remove the retaining bracket.
first image
Add Note Edit Step 31  ¶
  • Lift the hard drive up from the right side and remove it from the computer.
first image
Add Note Edit Step 32  ¶
  • Lift the optical drive out of the computer from the side with the connector on it.
first image
Add Note Edit Step 33  ¶
  • Remove the two 4 mm Phillips screws holding the USB board to the lower case.
first image
Add Note Edit Step 34  ¶
  • Lift the USB board out of the lower case.
first image
Add Note Edit Step 35  ¶
  • Remove the two Phillips screws securing the battery connector.
  • Remove the single Phillips screw holding the ground cable to the lower case.
  • Remove the battery connector from the lower case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 36  ¶
  • Remove the two Phillips screws securing the AirPort/Bluetooth card to the lower case.
  • Remove the AirPort/Bluetooth card from the lower case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 37  ¶
  • Remove the Phillips screws on the corners of the modem (two screws total).
  • Disconnect the modem from the cable on the left side and remove it from the computer.
first image
Add Note Edit Step 38  ¶
  • Remove the silver Phillips screw.
  • Remove the 5 mm hex nut screw.
  • These screws hold the DC & sound card to the lower case.
first image
Add Note Edit Step 39  ¶
  • Lift the DC & sound card out of the lower case.
  • Lower case remains.
For more information, check out the PowerBook G4 Aluminum 15" 1.67 GHz device page.
Did you successfully follow this guide?
This guide has been completed 2 times.
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 50+ in stock
Spudger
$2.95 · 50+ in stock
T6 Torx Screwdriver
$4.95 · 50+ in stock
Phillips #00 Screwdriver
5mm Nut Driver
$9.95 · 11 in stock
Related Products
$249.95 · 4 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 22 in stock
Sorting Tray
$7.95 · 16 in stock
Anti-Static Wrist Strap
$7.95 · 50+ in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$9.95 · 50+ in stock
