Page 1 of 1
Installing PowerBook G4 Aluminum 15" 1.67 GHz Inverter/Antenna Cables
Replace worn-through inverter and antenna cables on your PowerBook G4 Aluminum 15" 1.67 GHz.
- Author: Walter Galan
- Difficulty: Very difficult
Use this guide to replace worn-out inverter and antenna cables.
Sections
- Battery 1 step
- Upper Case 9 steps
- Left Ambient Light Sensor 1 step
- Left Speaker 2 steps
- PC Card Cage 3 steps
- Display Assembly 3 steps
- Rear Display Bezel 7 steps
- Clutch Cover 5 steps
- Inverter/Antenna Cables 1 step
Tools
Tools (continued)
Relevant parts
- View:
- Paginated
- Full width
Edit
Step 4
Rotate the computer 90 degrees clockwise so the power receptacle faces you.
Remove the three 3 mm Phillips screws along the edge of the lower case.
When replacing these screws, you must install them in the correct order. Begin by installing the screw closest to the display hinge, then work your way toward the front of the computer.
Edit
Step 6
Rotate the computer 90 degrees clockwise so the ports face you.
When replacing these screws, you must install them in the correct order. Begin by installing the screw closest to the display hinge, then work your way toward the front of the computer. Also, be careful not to put the screws in the two holes on either side of the video out port.
Edit
Step 8
Grasp the back corners of the upper case and pull up.
Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
Edit
Step 18
Support the display with one hand as you remove the remaining T8 screws.
Remove the upper two full thread 10 mm T8 Torx screws from each side of the display, then the two lower shanked 13 mm screws (four screws total).
When replacing the display, make sure that the correct screw pins down the ground loop from the display data cable.
Disconnect the two antenna cables from the airport/bluetooth card (shown in yellow circles), as well as the display cable (wide connector right hand upper corner) and the cable on top left corner of the logic board.
Edit
Step 22
With your spudger still inserted under the front display bezel, run it around the lower left corner of the display.
Rotate the spudger away from yourself to pry the rear display bezel off the aluminum tabs on the front display bezel.
Work your way down the side of the display until the rear display bezel has been separated from the front display bezel.
Edit
Step 24
Repeat the previous steps to separate the right side of the rear display bezel from the display.
Use your spudger to pry the plastic retaining clips on the rear display bezel over the raised aluminum tabs on the front display bezel.
At this point, the clips on the left and right edges of the rear display bezel should be free from the raised aluminum tabs on the front display bezel. If they are not, use a spudger to pry them past the front display bezel.
Edit
Step 29
Remove the five 2 mm Phillips screws securing the LCD retaining bracket to the front display bezel.
Lift the LCD retaining bracket off the front display bezel.
Some machines do not have this bracket. If your machine is missing the bracket, remove the five screws and proceed to the next step.
Edit
Step 30
The clutch cover is constructed from aluminum and is held on to the clutch hinges with metal clips that require a good deal of force to remove. Proceed with caution.
Use your thumbs to push the clutch cover away from the clutch hinges.
While pressing with your thumbs, rotate the clutch cover toward yourself about its long edge to pop it off the clutch hinge.
It may be necessary to wiggle the clutch cover while pressing it away from the clutch hinges to release the retaining clips.
This guide has been completed 0 times.
Page 1 of 1
