Page 1 of 1
Installing PowerBook G4 Aluminum 15" 1.67 GHz Hard Drive
- Author: Andrew Bookholt
- Difficulty: Moderate
Want more storage capacity? Replace your hard drive with a higher capacity unit.
- View:
- Paginated
- Full width
Edit Step 4 ¶
Rotate the computer 90 degrees clockwise so the power receptacle faces you.
Remove the three 3 mm Phillips screws along the edge of the lower case.
When replacing these screws, you must install them in the correct order. Begin by installing the screw closest to the display hinge, then work your way toward the front of the computer.
Edit Step 6 ¶
Rotate the computer 90 degrees clockwise so the ports face you.
When replacing these screws, you must install them in the correct order. Begin by installing the screw closest to the display hinge, then work your way toward the front of the computer. Also, be careful not to put the screws in the two holes on either side of the video out port.
Edit Step 8 ¶
Grasp the back corners of the upper case and pull up.
Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
Edit Step 17 ¶
Disconnect the hard drive cable from the hard drive using a spudger by gently loosening one side at a time. (Be careful not to pry to hard or you may bend the pins.) You may need to remove a piece of orange tape attaching the ribbon cable to the hard drive.
This is a bit tricky. If you bend the pins, do your best to straighten them using the hard drive cable as a guide.
If you are installing a new hard drive, we have an OS X install guide to get you up and running.
This guide has been completed 54 times.
Page 1 of 1
