Page 1 of 1
Installing PowerBook G4 Aluminum 15" 1.67 GHz Airport Extreme/Bluetooth Card
- Author: Andrew Bookholt
- Difficulty: Difficult
This guide will show you how to remove the Airport Extreme/Bluetoo
Sections
- Battery 1 step
- Upper Case 9 steps
- Left Ambient Light Sensor 1 step
- Left Speaker 2 steps
- PC Card Cage 3 steps
- Airport Extreme/Bluetooth Card 3 steps
Files
Tools
Relevant parts
- View:
- Paginated
- Full width
Edit Step 4 ¶
Rotate the computer 90 degrees clockwise so the power receptacle faces you.
Remove the three 3 mm Phillips screws along the edge of the lower case.
When replacing these screws, you must install them in the correct order. Begin by installing the screw closest to the display hinge, then work your way toward the front of the computer.
Edit Step 6 ¶
Rotate the computer 90 degrees clockwise so the ports face you.
When replacing these screws, you must install them in the correct order. Begin by installing the screw closest to the display hinge, then work your way toward the front of the computer. Also, be careful not to put the screws in the two holes on either side of the video out port.
Edit Step 8 ¶
Grasp the back corners of the upper case and pull up.
Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
This guide has been completed 5 times.
Page 1 of 1
