View profile
Teams
Order History
Logout
« Previous
Next »
Page 2 of 7
Rotate the upper case up and toward the screen, so that the upper case rests against it.
Remove the orange tape securing the trackpad ribbon to the logic board.
Disconnect the trackpad ribbon from the logic board.
Remove the upper case from the computer.
Remove the 9.5 mm silver Phillips screw from the top of the right ambient light sensor board.
Remove the small 3 mm black Phillips screw from the bottom of the board.
Lift the right ambient light sensor board from the computer.
Remove the two black Phillips screws from the right speaker.
Lift the speaker away from the logic board and place it aside
Use your fingernail to flip up the black plastic flap locking the modem cable in place.
Slide the modem cable from its connector.
Disconnect the 13 indicated cables, removing tape as necessary.
When re-installing the board, make sure the two small connectors at the right hand side are above the board before inserting the screws.
Remove the following 8 Phillips screws from the logic board:
Three 6.5 mm in the upper left corner.
Five 4.5 mm around the edges.
Next » « Previous
$6.95 · 42 In stock
$7.95 · 26 In stock
$2.95 · 50+ In stock
$4.95 · 13 In stock
$4.95 · 50+ In stock
$19.95
$29.95 · 50+ In stock
$39.95 · 17 In stock
$24.95
$24.95 · 10 In stock
1024
