Installing PowerBook G4 Aluminum 15" 1.5-1.67 GHz Right Clutch Hinge
Replace the right clutch hinge on the display of your 1.5-1.67 GHz 15" Aluminum PowerBook G4.
  • Add Note x
Replace a clutch hinge to keep your display opening smoothly.
Sections
first image
  • Use a coin to turn the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
first image
Add Note Edit Step 2 — Upper Case  ¶
  • Remove the four Phillips screws from the memory door.
  • Slide the memory door away from the memory compartment.
first image
Add Note Edit Step 3  ¶
  • Remove the following 8 screws:
    • Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
    • Two 12 mm Phillips on either side of the memory compartment.
    • Four 16 mm Phillips along the hinge.
Next » « Previous
