Page 1 of 1
Installing PowerBook G4 Aluminum 15" 1.5-1.67 GHz Front Display Bezel
Replace the front display bezel on your 1.5-1.67 GHz 15" Aluminum PowerBook G4.
- Author: Walter Galan
- Difficulty: Very difficult
Use this guide to replace a fatigued or cosmetically damaged front display bezel.
Sections
- Battery 1 step
- Upper Case 9 steps
- Right Ambient Light Sensor 2 steps
- Logic Board 10 steps
- Speakers 5 steps
- PC Card Cage 2 steps
- Display 8 steps
- Rear Display Bezel 9 steps
- Front Display Bezel 15 steps
Tools
Tools (continued)
- Arctic Silver Thermal Paste
- Coin
- Phillips #00 Screwdriver
- Plastic Opening Tools
- Spudger
- T6 Torx Screwdriver
- T8 Torx Screwdriver
Relevant parts
- View:
- Paginated
- Full width
Edit
Step 8
Grasp the back corners of the upper case and pull up. Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
Edit
Step 17
Two cables still connect to the logic board and must be removed before pulling the board entirely out of the computer.
Use a spudger to gently (very gently) pry up the left side of the logic board.
If the logic board does not immediately come free, it may be necessary to soften the thermal paste between the logic board and heat sink. You can soften the thermal compound using a hairdryer. Move the hairdryer back and forth between the two fans about one inch above the logic board for one minute. At this point, the logic board should now come free easily.
Edit
Step 20
Grasp the logic board at the left edge with one hand and at the thinnest section with the other hand. Lift the left edge of the board up to approximately a 30 degree angle (if you don't have your protractor handy, just lift until the DVI port clears the right hinge).
Once the logic board clears the ports, slide it out to the left.
Edit
Step 21
Important: when you reinstall a logic board, you'll need to replace the thermal paste that goes between the processor on the logic board and the heat sink. Failure to remove the old paste and apply a new layer can cause the computer to overheat and sustain damage. The following steps refer to replacing the thermal paste between the processor and heat sink; follow these steps only when you are ready to place the logic board in the computer.
Use a firm plastic edge to scrape the thermal material off the heat sink .
Apply a new layer of thermal paste to the heat sink
Edit
Step 22
Use a firm plastic edge to scrape the thermal material off the processor.
When replacing the logic board, make sure all cables are routed around and above - not under - it, and to connect the two cables that do go beneath before pushing the board into place.
Place the logic board back in the computer, trying not to move it around once the processor has come into contact with the newly-applied thermal paste.
Edit
Step 31
Lift the Airport card out of the computer and slide a spudger between the card and the antenna connector to disconnect the cable from the card.
Deroute the antenna cable from the side of the card, removing tape as necessary.
You don't need to remove the Airport card entirely. We're just trying to free up the Airport antenna cable.
Edit
Step 40
With your spudger still inserted under the front display bezel, run it around the lower left corner of the display.
Rotate the spudger away from yourself to pry the rear display bezel off the aluminum tabs on the front display bezel.
Work your way down the side of the display until the rear display bezel has been separated from the front display bezel.
Edit
Step 42
Repeat the previous steps to separate the right side of the rear display bezel from the display.
Use your spudger to pry the plastic retaining clips on the rear display bezel over the raised aluminum tabs on the front display bezel.
At this point, the clips on the left and right edges of the rear display bezel should be free from the raised aluminum tabs on the front display bezel. If they are not, use a spudger to pry them past the front display bezel.
Edit
Step 53
Flip your display over so the front bezel is facing up.
Lift the front bezel off the LCD enough to insert the flat end of a spudger between the metal LCD frame and the front display bezel.
Trying to insert your spudger between the LCD glass and the metal LCD frame will surely damage your LCD
Run your spudger along the lower edge of the front display bezel to separate the adhesive from the LCD frame.
Edit
Step 56
Remove the five Phillips screws securing the LCD retaining bracket to the front display bezel.
Lift the LCD retaining bracket off the front display bezel.
Some machines do not have this bracket. If your machine is missing the bracket, remove the five screws and proceed to the next step.
Edit
Step 57
The clutch cover is constructed from aluminum and is held on to the clutch hinges with metal clips that require a good deal of force to remove. Proceed with caution.
Use your thumbs to push the clutch cover away from the clutch hinges.
While pressing with your thumbs, rotate the clutch cover toward yourself about its long edge to pop it off the clutch hinge.
It may be necessary to wiggle the clutch cover while pressing it away from the clutch hinges to release the retaining clips.
Repeat this process for the other side of the clutch cover. Once the clutch cover is completely free from the clutch hinges, lift it off the front display bezel.
This guide has been completed 0 times.
Page 1 of 1
