Installing PowerBook G4 Aluminum 15" 1.5-1.67 GHz Airport Extreme Card
  • Author: iRobot
  • Difficulty: Difficult
  • Add Note x
Install an Airport Extreme 802.11g card internally.
first image
  • Use a coin to turn the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
first image
Add Note Edit Step 2 — Upper Case  ¶
  • Remove the four Phillips screws from the memory door.
  • Slide the memory door away from the memory compartment.
first image
Add Note Edit Step 3  ¶
  • Remove the following 8 screws:
    • Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
    • Two 12 mm Phillips on either side of the memory compartment.
    • Four 16 mm Phillips along the hinge.
first image
Add Note Edit Step 4  ¶
  • Rotate the computer 90 degrees clockwise, so that the power receptacle faces you.
  • Remove the three 3 mm Phillips screws.
  • When replacing these screws, you must place each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
first image
Add Note Edit Step 5  ¶
  • Turn the computer 90 degrees clockwise so that the hinge faces you.
  • Remove the bottom 5 mm Phillips screw on either side of the hinge (two total).
first image
Add Note Edit Step 6  ¶
  • Rotate the computer 90 degrees clockwise, so that the ports face you.
first image
Add Note Edit Step 7  ¶
  • Turn the computer over and open the display.
  • Remove the two 1.5 mm hex screws in either corner, next to the display (a T6 Torx driver will work, but repeated use will strip the screws).
first image
Add Note Edit Step 8  ¶
  • Grasp the back corners of the upper case and pull up. Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
  • Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
first image
Add Note Edit Step 9  ¶
  • Rotate the upper case up and toward the screen, so that the upper case rests against it.
first image
Add Note Edit Step 10  ¶
  • Remove the orange tape securing the trackpad ribbon to the logic board.
  • Disconnect the trackpad ribbon from the logic board.
  • Remove the upper case from the computer.
first image
Add Note Edit Step 11 — Right Ambient Light Sensor  ¶
    • Remove the 9.5 mm silver Phillips screw from the top of the right ambient light sensor board.
    • Remove the small 3 mm black Phillips screw from the bottom of the board.
first image
Add Note Edit Step 12  ¶
  • Lift the right ambient light sensor board from the computer.
first image
Add Note Edit Step 13 — Logic Board  ¶
  • Remove the two black Phillips screws from the right speaker.
  • Lift the speaker away from the logic board and place it aside
first image
Add Note Edit Step 14  ¶
  • Use your fingernail to flip up the black plastic flap locking the modem cable in place.
  • Slide the modem cable from its connector.
first image
Add Note Edit Step 15  ¶
  • Disconnect the 13 indicated cables, removing tape as necessary.
  • When re-installing the board, make sure the two small connectors at the right hand side are above the board before inserting the screws.
first image
Add Note Edit Step 16  ¶
  • Remove the following 8 Phillips screws from the logic board:
    • Three 6.5 mm in the upper left corner.
    • Five 4.5 mm around the edges.
first image
Add Note Edit Step 17  ¶
  • Two cables still connect to the logic board and must be removed before pulling the board entirely out of the computer.
  • Use a spudger to gently (very gently) pry up the left side of the logic board.
  • If the logic board does not immediately come free, it may be necessary to soften the thermal paste between the logic board and heat sink. You can soften the thermal compound using a hairdryer. Move the hairdryer back and forth between the two fans about one inch above the logic board for one minute. At this point, the logic board should now come free easily.
first image
Add Note Edit Step 18  ¶
  • Disconnect the DC-In connector from the left side of the logic board.
first image
Add Note Edit Step 19  ¶
  • Disconnect the battery cable from the front, left corner of the logic board.
first image
Add Note Edit Step 20  ¶
  • Grasp the logic board at the left edge with one hand and at the thinnest section with the other hand. Lift the left edge of the board up to approximately a 30 degree angle (if you don't have your protractor handy, just lift until the DVI port clears the right hinge).
  • Once the logic board clears the ports, slide it out to the left.
first image
Add Note Edit Step 21  ¶
  • Important: when you reinstall a logic board, you'll need to replace the thermal paste that goes between the processor on the logic board and the heat sink. Failure to remove the old paste and apply a new layer can cause the computer to overheat and sustain damage. The following steps refer to replacing the thermal paste between the processor and heat sink; follow these steps only when you are ready to place the logic board in the computer.
  • Use a firm plastic edge to scrape the thermal material off the heat sink .
  • Apply a new layer of thermal paste to the heat sink
first image
Add Note Edit Step 22  ¶
  • Use a firm plastic edge to scrape the thermal material off the processor.
  • When replacing the logic board, make sure all cables are routed around and above - not under - it, and to connect the two cables that do go beneath before pushing the board into place.
  • Place the logic board back in the computer, trying not to move it around once the processor has come into contact with the newly-applied thermal paste.
first image
Add Note Edit Step 23 — Speakers  ¶
  • Remove the two 3 mm black Phillips screws from the left ambient light sensor board.
  • Lift the left ambient light sensor board out of the computer, removing tape as necessary.
first image
Add Note Edit Step 24  ¶
  • Deroute the Bluetooth and RJ-11 cables from around the left side of the speaker.
first image
Add Note Edit Step 25  ¶
  • Disconnect the speaker cable from the DC/Sound card.
first image
Add Note Edit Step 26  ¶
  • Remove the 4 mm hex nut from below the left speaker.
  • Remove the 3 mm black Phillips screw from bottom left corner of the speaker assembly, to the left of the battery compartment.
first image
Add Note Edit Step 27  ¶
  • Lift the speaker assembly (including the right speaker) out of the computer.
first image
Add Note Edit Step 28 — PC Card Cage  ¶
  • Remove the two 4.2 mm silver Phillips screws from the left corners of the PC card cage.
  • Next the two 6.8 mm shouldered screws go on the right side of the card cage.
first image
Add Note Edit Step 29  ¶
  • Lift the PC card cage up and remove it from the computer.
  • When replacing the PC card cage, make sure you attach it to the post on the metal eject button.
first image
Add Note Edit Step 30 — Airport Extreme Card  ¶
  • Remove the two silver Phillips screws from either side of the large orange Airport ribbon.
first image
Add Note Edit Step 31  ¶
  • Lift the Airport card out of the computer and slide a spudger between the card and the antenna connector to disconnect the cable from the card.
  • Deroute the antenna cable from the side of the card, removing tape as necessary.
  • You don't need to remove the Airport card entirely. We're just trying to free up the Airport antenna cable.
first image
Add Note Edit Step 32  ¶
  • Disconnect the wide orange ribbon cable from the Airport card.
For more information, check out the PowerBook G4 Aluminum 15" 1.5-1.67 GHz device page.
Did you successfully follow this guide?
This guide has been completed 2 times.
Required Tools
Spudger
$2.95 · 50+ in stock
T6 Torx Screwdriver
$4.95 · 50+ in stock
Phillips #00 Screwdriver
4mm Nut Driver
$9.95 · 15 in stock
Coin
$2.95 · 11 in stock
Related Products
$39.95 · 50+ in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 22 in stock
Sorting Tray
$7.95 · 16 in stock
Anti-Static Wrist Strap
$7.95 · 50+ in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$9.95 · 50+ in stock
