Page 1 of 1
Installing PowerBook G4 Aluminum 15" 1-1.5 GHz Optical Drive Replacement
- Author: Andrew Bookholt
- Difficulty: Difficult
This guide will show you how to remove the brackets from the PowerBook G4 optical drive.
Sections
- Battery 1 step
- Upper Case 13 steps
- Optical Drive 5 steps
- Optical Drive Replacement 3 steps
Files
Tools
Tools (continued)
Relevant parts
- View:
- Paginated
- Full width
Edit Step 8 ¶
This step covers the hardest part to get inside this computer. Take a deep breath and think happy thoughts.
Grasp the back corners of the upper case and pull up, disengaging hidden tabs on the sides. Do not pull the upper case off yet; you still need to free tabs in the front of the case.
The seam is beneath the plastic molding on the upper case.
Edit Step 9 ¶
There is one latch that stops you from pulling the upper case right off, located on the left side of the optical drive slit. To free the upper case, you will be pulling a thin metal latch toward you, freeing it from the clasp holding it in place.
Pry up the left side of the upper case slightly with your hand and wedge a spudger into the seam between the upper case and lower case.
Leave the tool in place applying pressure to the upper case for the next step.
Edit Step 10 ¶
Place enough pressure on the upper case to allow you to slide a tool just within the seam between upper case and lower case as shown in the picture. A dentist's hook, push pin, or similar tool will work.
Do not yank the upper case off as soon as you free the clasp. The case is attached to the logic board via two ribbon cables.
Delicately slip the tip of your tool behind the silver metal latch and pull it forward while pulling up on the case. This may take some effort.
Alternatively, you can free the clasp with a small flathead screwdriver through the CD slot. The clasp is 1-3/16 in (3cm) from the left side of the slot. Use the screwdriver to lift out (or press back) the felt lining; then use the screwdriver to pull the clasp (shiny metal) forward to free it from the catch behind it (dull metal).
Edit Step 11 ¶
Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
Rotate the upper case up and toward the screen, so that the upper case rests against it.
Edit Step 14 ¶
Loosen the keyboard ribbon clamp by pushing the thin black piece toward the screen, using the tips of your fingers.
The black piece is very fragile and easily broken. Use care when separating it from the main socket.
Slide the grey keyboard ribbon out of the loosened connector.
Remove the upper case from the computer.
Edit Step 19 ¶
Lift the optical drive out of the computer from the side with the connector on it (mind the small metal bracket that pops out with the drive, keep this with the optical drive).
Don't forget the bracket when reassembling the computer.
If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
This guide has been completed 10 times.
Page 1 of 1
