Installing PowerBook G4 Aluminum 15" 1-1.5 GHz Airport Extreme Card
  • Author: iRobot
  • Difficulty: Easy
  • Add Note x
  • x 5
Install an Airport Extreme 802.11g card internally.
Sections
Files
Tools
Relevant parts
first image
  • Use a coin to turn the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
first image
Add Note Edit Step 2 — Airport Extreme Card  ¶
  • Flip down the door on the right side of the battery compartment.
first image
Add Note Edit Step 3  ¶
  • Use a spudger or flathead screwdriver to disconnect the Airport antenna from the card.
first image
Add Note Edit Step 4  ¶
  • Grasp the plastic tab and pull the card out all the way.
For more information, check out the PowerBook G4 Aluminum 15" 1-1.5 GHz device page.
Did you successfully follow this guide?
This guide has been completed 5 times.
Required Tools
Coin
$2.95 · 11 in stock
Related Products
$39.95 · 50+ in stock
