Installing PowerBook G4 Aluminum 12" 867 MHz RAM
  • Author: iRobot
  • Difficulty: Easy
  • Add Note x
  • x 3
One RAM slot will accept PC2100 or PC2700 chips up to 1 GB.
first image
  • Use a coin to turn the battery locking screw 90 degrees to the right.
  • Lift the battery out of the computer.
first image
Add Note Edit Step 2 — RAM  ¶
  • Remove the four Phillips screws from the memory door.
  • Slide the memory door away from the memory compartment.
first image
Add Note Edit Step 3  ¶
  • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  • Pull the chip directly out from its connectors.
For more information, check out the PowerBook G4 Aluminum 12" 867 MHz device page.
Did you successfully follow this guide?
This guide has been completed 3 times.
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Coin
$2.95 · 11 in stock
Related Products
PC2700 1 GB RAM Chip
$54.95 · 9 in stock
PC2700 512 MB RAM Chip
$39.95 · 12 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 22 in stock
Sorting Tray
$7.95 · 16 in stock
Anti-Static Wrist Strap
$7.95 · 50+ in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$9.95 · 50+ in stock
