Installing PowerBook G4 Aluminum 12" 1-1.5 GHz Keyboard
  • Author: iRobot
  • Difficulty: Moderate
  • Add Note x
  • x 10
This guide shows the hidden screws you must remove when replacing the keyboard.
Sections
Files
first image
  • Use a coin to turn the battery locking screw 90 degrees to the right.
  • Lift the battery out of the computer.
first image
Add Note Edit Step 2 — EMI Finger  ¶
  • Remove the four Phillips screws from the memory door.
  • Slide the memory door away from the memory compartment.
first image
Add Note Edit Step 3  ¶
  • Remove the long black Phillips screw next to the memory card.
  • Remove the small EMI finger beneath the black screw.
Next » « Previous
