Image #1
Add Note Edit Step 9  ¶
  • Remove the two short Phillips screws.
Image #1
Add Note Edit Step 10  ¶
  • Lift the keyboard by the 'esc' and 'eject' keys and gently lift up until the keyboard is vertical.
Image #1
Add Note Edit Step 11  ¶
  • Grasp the keyboard connector ribbon near the connector and disconnect it from the logic board.
Image #1
Add Note Edit Step 12 — Upper Case  ¶
  • Remove the three 2.5mm Phillips screws from within the battery compartment.
Image #1
Add Note Edit Step 13  ¶
  • Turn the computer 90 degrees clockwise and remove the two Phillips screws from the casing.
  • Outside case screws are aprox. 1/4 in long
Image #1
Add Note Edit Step 14  ¶
  • Turn the computer 90 degrees clockwise again, and remove only the bottom screw on either side of the hinge.
Image #1
Add Note Edit Step 15  ¶
  • Turn the computer 90 degrees clockwise just one more time, and remove the two Phillips screws on the exterior wall of the battery compartment.
  • Note: For reassembly the two screws have long necks.
Image #1
Add Note Edit Step 16  ¶
  • Turn the computer over and open it up.
  • Remove the following 14 screws:
    • Six 2.5 mm Phillips on either side of the keyboard area.
    • Five 4.5 mm Phillips on the left half of the keyboard area.
    • One 7 mm hex in the upper left corner of the upper case (a T6 Torx driver will do the job nicely).
    • One 15 mm Phillips in the upper middle of the keyboard area.
    • One 16.5 mm hex in the upper right of the upper case (again, a T6 Torx driver will work well).
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
T6 Torx Screwdriver
$4.95 · 50+ In stock
Phillips #00 Screwdriver
4mm Nut Driver
$9.95 · 8 In stock
Coin
$2.95 · 20 In stock
Related Products
G4 Aluminum 12" Clutch Cover
$19.95 · 21 In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 6 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
