first image
Add Note Edit Step 13 — Modem  ¶
  • Remove the single Phillips screw from the modem.
  • Disconnect the orange PMU cable by pulling it directly up.
first image
Add Note Edit Step 14  ¶
  • Disconnect the modem from the logic board by lifting up on the right side using a spudger, the tip of your finger, or a flat non-metal tool.
  • Remove the modem by sliding it up and to the right.
first image
Add Note Edit Step 15  ¶
  • Your laptop should look approximately like this.
Next » « Previous
For more information, check out the PowerBook G3 Wallstreet device page.
Did you successfully follow this guide?
This guide has been completed 0 times.
