first image
Add Note Edit Step 7 — Heat Shield  ¶
  • Remove the two Phillips screws from the heat shield.
  • One screw is shorter than the other. When putting the Wallstreet back together, this screw goes in the middle of the heat shield.
first image
Add Note Edit Step 8  ¶
  • Grasp the metal handle on the heat shield and pull up and toward yourself.
first image
Add Note Edit Step 9 — Hard Drive  ¶
  • Unscrew, but do not remove, the single Phillips screw from the hard drive bracket.
Next » « Previous
