Page 1 of 1
Installing PowerBook G3 Pismo Processor
- Author: iRobot
- Difficulty: Easy
This processor is not soldered to the logic board, and installing a replacement is very easy. There are processor upgrades that enable you to turn your Pismo into a G4.
Sections
- Keyboard 3 steps
- Heat Shield 2 steps
- Airport Card 2 steps
- PRAM Battery 2 steps
- Heat Sink 2 steps
- Processor 2 steps
Files
- View:
- Paginated
- Full width
Edit Step 2 ¶
Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
Edit Step 11 ¶
Lift the heat sink up from the left side and pull it out.
If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
Edit Step 12
Processor
Grasp the plastic tab on the processor's right side and pull it directly up.
Some processors may be missing the plastic pull tab. In this case, we suggest using a non-metal tool to gently pry up the processor. Slip the tool's thin edge under the front right corner of the processor and carefully pry it up.
This guide has been completed 5 times.
Page 1 of 1
