Installing PowerBook G3 Pismo Optical Drive
  • Author: iRobot
  • Difficulty: Easy
  • Add Note x
  • x 3
It's easy to change or upgrade the optical drive mechanism to a combo or SuperDrive.
first image
Add Note Edit Step 1 — Optical Drive  ¶
  • Use the lever at the front of your laptop to remove the optical drive bay from the computer.
  • Remove the 2 Phillips #00 screws from the left side of the optical drive housing.
  • These screws are longer than those on the other side.
first image
Add Note Edit Step 2  ¶
  • Remove the 2 Phillips #00 screws from the other side.
first image
Add Note Edit Step 3  ¶
  • Grasp the black drive housing in one hand and the drive itself in the other, then slide the two apart.
  • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
For more information, check out the PowerBook G3 Pismo device page.
Did you successfully follow this guide?
This guide has been completed 3 times.
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Related Products
Recommended Tools
Home Tech Toolkit
$24.95 · 22 in stock
Sorting Tray
$7.95 · 16 in stock
Anti-Static Wrist Strap
$7.95 · 50+ in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$9.95 · 50+ in stock
