Page 1 of 1
Installing PowerBook G3 Pismo Inverter
- Author: iRobot
- Difficulty: Easy
The inverter powers the LCD backlight and is not a difficult part to replace.
Sections
- Keyboard 3 steps
- Heat Shield 2 steps
- Airport Card 2 steps
- PRAM Battery 2 steps
- Heat Sink 2 steps
- Processor 2 steps
- Modem 3 steps
- Hard Drive 3 steps
- Clutch Cover 2 steps
- Inverter 4 steps
Files
Tools
Relevant parts
- View:
- Paginated
- Full width
Edit Step 2 ¶
Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
Edit Step 11 ¶
Lift the heat sink up from the left side and pull it out.
If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
Edit Step 12
Processor
Grasp the plastic tab on the processor's right side and pull it directly up.
Some processors may be missing the plastic pull tab. In this case, we suggest using a non-metal tool to gently pry up the processor. Slip the tool's thin edge under the front right corner of the processor and carefully pry it up.
Edit Step 23 ¶
Remove the single black Torx screw that fastens the display cable to the plastic casing.
Grasp the thin display inverter board at its left end; lift up and rotate toward yourself.
There are two tabs that hold the display inverter in place; these are what you need to get past in order to pull the board free.
This guide has been completed 1 time.
Page 1 of 1
