Page 1 of 1
Installing PowerBook G3 Pismo I/O EMI Shield
- Author: iRobot
- Difficulty: Moderate
A thin metal shield resides above the ports that protects from electromagnetic interference.
Sections
- Keyboard 3 steps
- Heat Shield 2 steps
- Airport Card 2 steps
- PRAM Battery 2 steps
- Heat Sink 2 steps
- Processor 2 steps
- Modem 3 steps
- Hard Drive 3 steps
- Clutch Cover 2 steps
- Inverter 4 steps
- Display 4 steps
- Upper Case 9 steps
- View:
- Paginated
- Full width
Edit
Step 2
Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
Edit
Step 11
Lift the heat sink up from the left side and pull it out.
If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
Edit
Step 12
Processor
Grasp the plastic tab on the processor's right side and pull it directly up.
Some processors may be missing the plastic pull tab. In this case, we suggest using a non-metal tool to gently pry up the processor. Slip the tool's thin edge under the front right corner of the processor and carefully pry it up.
Edit
Step 23
Remove the single black Torx screw that fastens the display cable to the plastic casing.
Grasp the thin display inverter board at its left end; lift up and rotate toward yourself.
There are two tabs that hold the display inverter in place; these are what you need to get past in order to pull the board free.
Edit
Step 37
Lift the left side of the case partly up so that you can access and disconnect the audio in/out cables from the sound card in the upper right of the case.
Be careful not to lift the upper casing too far before you have disconnected the audio in/out cables or you may damage the sound card.
Remove the upper casing. Note that there are two tabs on the laptop's front that often cause the upper case to stick.
Edit
Step 41
I/O EMI Shield
Gently clasp the left side of the metal shield between your thumb and forefinger and carefully pull up and toward the front of the laptop.
Be very careful when removing the leftmost clip on the EMI Shield from its slot, as this piece will bend very easily. This is one of the easiest parts to damage in the Pismo.
This guide has been completed 0 times.
Page 1 of 1
