Installing PowerBook G3 Pismo Hard Drive
Prerequisite Only
Prerequisite Only
This guide is only used as a prerequisite for other guides and is not a complete or useful guide when viewed independently.
  • Author: iRobot
  • Difficulty: Easy
  • Add Note x
  • x 4
How to remove the hard drive, along with its cable and bracket from your computer.
Sections
first image
Add Note Edit Step 1 — Keyboard  ¶
  • Turn the keyboard locking screw so that it is parallel to the space bar.
  • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
first image
Add Note Edit Step 2  ¶
  • Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
  • The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
  • Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
first image
Add Note Edit Step 3  ¶
  • Your laptop should look approximately like this.
first image
Add Note Edit Step 4 — Heat Shield  ¶
  • Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
  • Lift the heat shield up and pull it toward you.
first image
Add Note Edit Step 5  ¶
first image
Add Note Edit Step 6 — Airport Card  ¶
  • Skip this step if your computer does not have an Airport card installed.
  • Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
  • The Airport card is still attached to the antenna cable, so don't just yank it out of the slot.
first image
Add Note Edit Step 7  ¶
  • Disconnect the antenna cable from the Airport card.
first image
Add Note Edit Step 8 — Heat Sink  ¶
  • Remove the long silver Phillips #1 screw from the heat sink.
  • Remove the two T8 Torx screws that attach the heat sink to the processor.
first image
Add Note Edit Step 9  ¶
  • Lift the heat sink up from the left side and pull it out.
  • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
first image
Add Note Edit Step 10 — Processor  ¶
  • Grasp the plastic tab on the processor's right side and pull it directly up.
  • Some processors may be missing the plastic pull tab. In this case, we suggest using a non-metal tool to gently pry up the processor. Slip the tool's thin edge under the front right corner of the processor and carefully pry it up.
first image
Add Note Edit Step 11  ¶
first image
Add Note Edit Step 12 — Hard Drive  ¶
  • Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
  • Try to grasp the cable on the plastic connector rather than on the flexible cable section.
first image
Add Note Edit Step 13  ¶
  • Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
first image
Add Note Edit Step 14  ¶
For more information, check out the PowerBook G3 Pismo device page.
Did you successfully follow this guide?
This guide has been completed 4 times.
Required Tools
Phillips #0 Screwdriver
$4.95 · 50+ in stock
T8 Torx Security Bit Screwdriver
$6.95 · 50+ in stock
Anti-Static Wrist Strap
$7.95 · 50+ in stock
Spudger
$2.95 · 50+ in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 22 in stock
Sorting Tray
$7.95 · 16 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$9.95 · 50+ in stock
Popular Device Products
Universal Drive Adapter
$29.95 · 28 in stock
Airport Card
$49.95 · 1 in stock
