Page 1 of 1
Installing PowerBook G3 Lombard Power Card
- Author: iRobot
- Difficulty: Difficult
The power card connects your batteries to the computer.
Sections
- Keyboard 3 steps
- Heat Shield 3 steps
- PRAM Battery 2 steps
- Modem 4 steps
- Processor 3 steps
- RAM 1 step
- Hard Drive 2 steps
- Clutch Cover 3 steps
- Inverter 5 steps
- Display 3 steps
- Upper Case 9 steps
- Power Card 1 step
Files
Tools
Relevant parts
- View:
- Paginated
- Full width
Edit
Step 16
RAM
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
Pull the RAM chip out.
There are RAM slots on both sides of the processor. We recommend installing higher capacity chips on the bottom so that if you want to upgrade later, you won't have to remove the processor.
Edit
Step 36
Lift the left side of the case partly up so that you can access and disconnect the audio in/out cables from the sound card in the upper right of the case.
Be careful not to lift the upper casing too far before you have disconnected the audio in/out cables or you may damage the sound card.
This guide has been completed 0 times.
Page 1 of 1
