Installing PowerBook G3 Lombard PRAM Battery
  • Author: iRobot
  • Difficulty: Easy
  • Add Note x
The time and date, as well as other settings, are kept by the PRAM battery when your machine is off.
Sections
Files
first image
Add Note Edit Step 1 — Keyboard  ¶
  • Turn the computer so that the ports are facing you.
  • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
first image
Add Note Edit Step 2  ¶
  • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
first image
Add Note Edit Step 3  ¶
  • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
  • In order to replace the keyboard, you must first remove the modem.
first image
Add Note Edit Step 4 — Heat Shield  ¶
  • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
first image
Add Note Edit Step 5  ¶
  • Lift the heat shield up and pull it toward you.
first image
Add Note Edit Step 6  ¶
  • Your laptop should look approximately like this.
first image
Add Note Edit Step 7 — PRAM Battery  ¶
  • Pull the battery cable directly up from the logic board.
first image
Add Note Edit Step 8  ¶
  • Remove the battery from its holder by pulling up and to the left.
For more information, check out the PowerBook G3 Lombard device page.
Did you successfully follow this guide?
This guide has been completed 2 times.
Required Tools
Phillips #0 Screwdriver
$4.95 · 50+ in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 22 in stock
Sorting Tray
$7.95 · 16 in stock
Anti-Static Wrist Strap
$7.95 · 50+ in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$9.95 · 50+ in stock
Popular Device Products
Universal Drive Adapter
$29.95 · 28 in stock
