View profile
Teams
Order History
Logout
« Previous
Page 6 of 6
Disconnect the fan cable from the left side of the logic board.
Turn the laptop so that its back is facing you.
Lift up on the left side of the metal framework and remove the single black Torx screw.
Grasp the EMI Filter by its black end and rotate it toward the front of the laptop. Pull the filter up and beyond the screw bracket.
Remove the metal framework.
Your laptop should look approximately like this.
Lift the sound card out by pulling up on both the right and left sides.
If the sound card sticks, pull the black metal wall of the casing toward you while lifting the right side of the sound card up.
Turn the laptop around so that the front faces you.
Move the metal yoke to the left, making sure to leave the spring attached.
Gently lift the front edge of the logic board and then pull it toward you.
There are two major obstacles to avoid when removing the logic board: the first is the fan and connector cables, and the second is the bolt in the back left corner.
Next » « Previous
$4.95 · 24 In stock
$6.95 · 38 In stock
$7.95 · 25 In stock
$2.95 · 50+ In stock
$69.95 · 2 In stock
$25.95 · 9 In stock
$29.95 · 50+ In stock
$39.95 · 17 In stock
$24.95
$24.95 · 10 In stock
1024
