Installing Power Mac G4 Cube Optical Drive
User-Contributed Guide
Markup Mishap
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Installing a new optical drive.
  • Author: Ryan Chun
  • Time required: 5 minutes
  • Difficulty: Moderate
Installing the optical drive involves removing the outer case before actual installation.
Image #1 Image #2 Image #3
Add Note Edit Step 1 — Outer Case  ¶
  • Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
  • Push back the handle after you have taken the core out of the case.
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Place the cube upside down and remove the four screws on the front plate. Then remove the two screws on each side.
Image #1
Add Note Edit Step 3  ¶
  • Slowly lift the plate off the cube and disconnect the power cord.
Image #1
Add Note Edit Step 4  ¶
  • Remove the four pillars from each corner.
  • The pillars should come out fairly easily.
Image #1
Add Note Edit Step 5 — Optical Drive  ¶
  • Remove a total of four screws on the sides of the optical drive.
Image #1
Add Note Edit Step 6  ¶
  • Slowly lift up the optical drive and remove the IDE cable.
  • Remove the power cable.
Required Tools
T10 Torx Security Bit Screwdriver
$6.95 · 50+ In stock
Popular Products
Universal Drive Adaptor
$29.95 · 50+ In stock
iPhone 4S Replacement Battery
Metal Spudger Set
$7.95 · 50+ In stock
Probe and Pick Set
