Image #1
Add Note Edit Step 25 — Top Shield Assembly  ¶
  • Disconnect the DC-In and Blu-ray power cables from the motherboard.
  • Pull the cables straight upward to lift the connectors up and out of their sockets on the motherboard.
Image #1
Add Note Edit Step 26  ¶
  • Pull the fan cables straight up to lift the fan connector up and out of its socket on the motherboard.
Image #1
Add Note Edit Step 27  ¶
  • Remove the following nine screws holding the motherboard assembly together:
    • Four 14.8 mm shouldered Phillips
    • Five 9.5 mm Phillips
Image #1
Add Note Edit Step 28  ¶
  • Remove the two heat sink clamps from the bottom of the motherboard assembly.
Image #1
Add Note Edit Step 29  ¶
  • If necessary, gently pry the motherboard off the top shield near the heat sink and its shroud.
Image #1 Image #2
Add Note Edit Step 30  ¶
  • Gently press the board away from the top shield assembly near the fan connector and the corner of the board near the wireless sockets.
Image #1
Add Note Edit Step 31  ¶
  • Lift the top shield assembly off the motherboard from its front edge.
  • Be careful not to damage the sockets as you rotate the top shield assembly away from the motherboard.
Image #1
Add Note Edit Step 32 — Motherboard  ¶
  • Carefully lift the motherboard off the bottom shield.
  • Handle the motherboard by its edges.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #1 Screwdriver
$4.95 · 5 In stock
Metal Spudger
$2.95 · 2 In stock
T8 Torx Security Bit Screwdriver
$6.95 · 44 In stock
Arctic Silver Thermal Paste
$8.95 · 50+ In stock
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 17 In stock
Portable Anti-Static Mat
$24.95 · 11 In stock
Popular Device Products
500 GB 5400 RPM 2.5" Hard Drive
$89.95 · 6 In stock
750 GB 7200 RPM 2.5" Hard Drive
$109.95 · 17 In stock
1 TB 5400 RPM 2.5" Hard Drive
$109.95 · 10 In stock
Arctic Silver ArctiClean
$7.95 · 50+ In stock
