Installing PlayStation 3 Slim Heat Sink
Replace your PS3 Slim's heat sink and its integrated fan shroud.
  • Add Note x
  • x 3
Use this guide to replace your heat sink. It is essential to apply a new layer of thermal paste during reassembly.
Sections
first image
Add Note Edit Step 1 — Top Cover  ¶
  • Turn the PS3 over and lay it on its backside.
  • Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
  • To avoid activating the VOID that may come up, heat the sticker carefully to remove and replace it cleanly.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
first image
Add Note Edit Step 3  ¶
  • Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
Next » « Previous
