Installing PlayStation 2 Disc Drive
User-Contributed Guide
  • Author: jwyoung
  • Time required: 60 to 75 minutes
  • Difficulty: Moderate
  • Add Note x
  • x 8
In the need that you need to replace the entire disc drive, here's what you need to do. You may need to do a little eBay perusing first, but when you find that replacement, these steps will show you how to remove your old one.
Sections
Image #1 Image #2 Image #3
Add Note Edit Step 1 — Top Cover  ¶
  • Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards.
  • Use the flat edge of a metal spudger to pry the eight flat screw covers out.
  • Remove the following eight screws securing the top cover to the bottom case:
    • Four 55.4 mm Philips screws
    • Four 18.0 mm Phillips screws
Image #1
Add Note Edit Step 2  ¶
  • Peel the warranty sticker (located next to the main power switch) straight away from the case.
  • To avoid activating the VOID that may come up, heat it carefully to remove and replace it clean
Image #1 Image #2
Add Note Edit Step 3  ¶
  • Flip the PlayStation 2 back to its original upside position.
  • Lift the top cover off the bottom case.
  • To facilitate the removal, it is recommended to pry open the half closer to the power switch first while rocking the top cover towards the front of the bottom case.
  • Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the bottom case.
Image #1 Image #2
Add Note Edit Step 4 — Power Board  ¶
  • Remove the two 6.4 mm black Phillips screws securing the optical disc drive to the bottom case.
  • Lift and remove the optical disc drive straight up out of the bottom case.
Image #1 Image #2
Add Note Edit Step 5  ¶
  • Remove the two 14.6 mm gold-headed Phillips securing the controller ports to the bottom case.
Image #1 Image #2
Add Note Edit Step 6  ¶
  • Gently lift the controller port board out of its recess within the bottom case.
  • Do not completely remove the controller port board. It is still attached via a ribbon cable.
  • Pull the controller port ribbon cable straight away from its socket on the controller port board.
  • Remove the controller port board out of the bottom case.
Image #1
Add Note Edit Step 7  ¶
  • Remove the two 14.6 mm gold Phillips screws securing the fan to the bottom case.
Image #1
Add Note Edit Step 8  ¶
  • If there is a device occupying the expansion bay, make sure to remove the device. The expansion base should be empty.
  • Pry and remove the expansion bay cover away from its posts on the bottom case.
Next » « Previous
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Phillips #1 Screwdriver
$4.95 · 27 In stock
Metal Spudger
$2.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 6 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
Popular Products
Metal Spudger
Heavy-duty Spudger
iPod Touch Gen 4 Adhesive Strips
$3.95 · 50+ In stock
Arctic Silver Thermal Paste
$8.95 · 50+ In stock
