Installing PSP Go Headphone Jack
  • Add Note x
Use this guide to replace your PSP Go's headphone jack!
Sections
Tools
Tools (continued)
Relevant parts
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Back Cover  ¶
  • Unscrew the four Phillips screws on the back of the PSP Go.
  • Rotate the PSP so you can see the top of the device.
  • Unscrew the two Phillips screws next to the volume buttons.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Use an PSP Go opening tool around the perimeter of the back cover to loosen it on all sides.
  • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
  • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
first image
Add Note Edit Step 3 — Top Cover  ¶
  • Pull the top cover upwards gently from its housing.
first image
thumb image 1
thumb image 2
Add Note Edit Step 4 — Bottom Plate  ¶
  • Remove the two Phillips screws holding the bottom plate.
  • Gently lift the bottom plate away from the device.
first image
Add Note Edit Step 5 — Headphone Jack  ¶
  • Remove the black Phillips screw holding the headphone jack in place.
first image
Add Note Edit Step 6  ¶
  • Use a pair of tweezers and grasp the black plastic portion of the headphone jack cable.
  • Slowly pull out the cable. If it's hard to pull, wiggle it slightly side-to-side while pulling it.
  • Plugging the new headphone jack into place will require some force. Make sure not to break the connector while performing this procedure. Grasp the black plastic portion of the cable and wiggle it into the logic board connector.
For more information, check out the PSP Go device page.
Did you successfully follow this guide?
This guide has been completed 0 times.
