Image #1
Add Note Edit Step 17 — Display  ¶
  • Use a #00 Phillips screwdriver to remove the four display screws.
Image #1 Image #2 Image #3
Add Note Edit Step 18  ¶
  • Wedge a PSP opening tool in the location shown in the first picture, and slightly separate the metal frame from the plastic front panel.
  • Slide the PSP opening tool around the perimeter of the display, increasing the gap between the metal frame and the front panel.
  • The front panel should now be free from the metal frame. However, it is still connected to the frame, so don't remove it completely.
Image #1 Image #2
Add Note Edit Step 19  ¶
  • Use a PSP opening tool to disconnect the display cable from the rest of the device.
  • The PSP Go should now look similar to the second picture.
Image #1 Image #2
Add Note Edit Step 20  ¶
  • Be very careful when performing this procedure! If you put too much pressure on the display, you risk cracking it.
  • Wedge a PSP opening tool between the plastic front panel and display. Be very careful that you wedge it in the same location shown in the first picture.
  • Slide the PSP opening tool across the length of the display. This should loosen the glue binding the display to the plastic front panel.
  • Rotate the display 180 degrees and free the bottom side of the display in the same manner.
Image #1
Add Note Edit Step 21  ¶
  • Gently separate the display from the front panel.
  • Match the orientation of the PSP logo on the display with the Sony logo on the front panel when reassembling the PSP Go.
Image #1
Add Note Edit Step 22 — Front Panel  ¶
  • Front panel remains.
Next » « Previous
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Plastic Opening Tools
$2.95 · 50+ In stock
Related Products
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 13 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
