first image
thumb image 1
thumb image 2
Add Note Edit Step 16  ¶
  • Use a PSP opening tool to disconnect the display cable from the logic board.
  • The D-pad may come loose while prying the logic board.
  • The logic board should now be free from the rest of the device.
  • During reassembly, make sure to properly line up the power button with the power button lever on the logic board.
first image
Add Note Edit Step 17 — Display  ¶
  • Use a #00 Phillips screwdriver to remove the four display screws.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 18  ¶
  • Wedge a PSP opening tool in the location shown in the first picture, and slightly separate the metal frame from the plastic front panel.
  • Slide the PSP opening tool around the perimeter of the display, increasing the gap between the metal frame and the front panel.
  • The front panel should now be free from the metal frame. However, it is still connected to the frame, so don't remove it completely.
Next » « Previous
