Installing PSP Go Analog Joystick
  • Add Note x
  • x 3
Use this guide to put a fresh analog joystick into the PSP Go!
Sections
Image #1 Image #2
Add Note Edit Step 1 — Back Cover  ¶
  • Unscrew the four Phillips screws on the back of the PSP Go.
  • Rotate the PSP so you can see the top of the device.
  • Unscrew the two Phillips screws next to the volume buttons.
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Use an PSP Go opening tool around the perimeter of the back cover to loosen it on all sides.
  • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
  • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
Image #1
Add Note Edit Step 3 — Top Cover  ¶
  • Pull the top cover upwards gently from its housing.
Image #1 Image #2
Add Note Edit Step 4 — Bottom Plate  ¶
  • Remove the two Phillips screws holding the bottom plate.
  • Gently lift the bottom plate away from the device.
Image #1
Add Note Edit Step 5 — Analog Joystick  ¶
  • Use a #00 Phillips screwdriver to remove both screws holding the analog joystick in place.
Image #1 Image #2
Add Note Edit Step 6  ¶
  • Use a PSP opening tool to gently flip up the analog joystick's cable connector.
  • Use your fingers or tweezers to gently pull out the analog joystick cable from its connector.
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Plastic Opening Tools
$2.95 · 50+ In stock
Related Products
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 7 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
