Image #1 Image #2 Image #3
Add Note Edit Step 17  ¶
  • Use your fingernail or the edge of a spudger to flip up the retaining flap on the UMD drive ribbon socket.
  • Be sure you are prying up on the retaining flap, not the socket itself
  • Use your fingernail or tip of a spudger to push both sides of the black retaining flap on the UMD laser ribbon socket to the right.
  • Use a spudger to gently pull both ribbon cables straight out of their sockets.
Image #1 Image #2
Add Note Edit Step 18  ¶
  • Flip the PSP 300xc over and open the UMD door.
  • Using a pair of tweezers, grab the small rubber square between the metal UMD brace and case, and lift it out of the PSP 300xc.
  • Repeat for the rubber square on the other side of the UMD door.
Add Note Edit Step 19  ¶
  • Slide the UMD brace toward the top of the UMD door until the brace disconnects from the door. Remove the brace.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Related Products
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 16 In stock
Inspection Scope
$39.95 · 38 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
