Installing PSP 300xc UMD Brace
Replacing the UMD brace in a PSP 300xc
Has the metal brace in your UMD drive broken? Follow this guide to replace it!
Sections
Image #1 Image #2
  • Press the button securing the battery door to the PSP 300xc, and lift the battery door off.
  • Lift the battery out of the PSP.
Image #1
Add Note Edit Step 2 — Front Case  ¶
  • Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
Image #1 Image #2
Add Note Edit Step 3  ¶
  • Remove four Phillips screws from the back of the PSP.
Image #1
Add Note Edit Step 4  ¶
  • Remove two Phillips screws from the top of the PSP.
Image #1
Add Note Edit Step 5  ¶
  • Remove a single screw from the bottom edge of the PSP.
Image #1 Image #2
Add Note Edit Step 6  ¶
  • Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it.
Image #1
Add Note Edit Step 7 — LCD  ¶
  • Remove a single Phillips screw securing the home bar to the PSP 300xc.
Image #1 Image #2
Add Note Edit Step 8  ¶
  • Push the home bar to the right about 1cm to release a tab, and begin to lift the right end of the home bar slightly.
  • Do not attempt to remove the home bar yet, it is still attached to the PSP 300xc.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Related Products
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 9 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
