Installing PSP 2000 Logic Board
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Author: espinks
  • Time required: 15-30 minutes
  • Difficulty: Difficult
  • Add Note x
  • x 4
Is your logic board acting illogical? Fix it!
Sections
first image
thumb image 1
thumb image 2
thumb image 3
  • Place PSP face down, so that the UMD Drive is facing upwards.
  • Locate the battery door and open.
  • Remove the battery from inside.
first image
Add Note Edit Step 2 — Front Casing  ¶
  • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty.
  • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
  • Remove the sticker using the PSP Opening Tools.
  • Under the sticker is a 5mm Phillips screw needed in the next step.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • Remove four 5 mm Phillips from the case.
  • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
Next » « Previous
