Image #1 Image #2 Image #3
Add Note Edit Step 9 — Memory Stick Slot  ¶
  • Remove two 4.5 mm Phillips screws from the left-hand side of the PSP.
  • Slide off the left trigger along with the plastic bracket underneath.
  • Carefully pry off left trigger button using opening tools.
  • The button is adhered to the body. It can be re-adhered with hot glue after being pried-up, if necessary.
Image #1 Image #2
Add Note Edit Step 10  ¶
  • Use an opening tool to lift up the brown tab on the connector and remove the cable horizontally.
  • Gently remove the memory card slot by pulling it straight out.
Image #1
Add Note Edit Step 11 — Logic Board  ¶
  • Remove the following four connections:
    • Two ribbon cables -- flip up latch and remove horizontally.
    • One wire clamp -- use an opening tool to pry it up vertically.
    • One wiring harness -- use your fingers, a PSP opening tool, or tweezers to disconnect the connector horizontally.
  • The ribbon cable near the wire clamp has a brown tab that should be lifted using an opening tool prior to removal. Be careful to not damage the ribbon or connector.
Image #1 Image #2
Add Note Edit Step 12  ¶
  • Remove metal shields by gently lifting them with an opening tool.
Add Note Edit Step 13  ¶
  • Double-check to make sure that all connections to the board are unplugged in order to avoid damage to your PSP.
  • Using an opening tool, delicately raise the logic board from its base.
Image #1 Image #2
Add Note Edit Step 14 — Audio Jack  ¶
  • With the logic board out of the way, remove the 4mm Phillips screw.
  • Carefully lift the headphone jack out of the casing.
Next » « Previous
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Plastic Opening Tools
$2.95 · 50+ In stock
Related Products
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 17 In stock
Portable Anti-Static Mat
$24.95 · 10 In stock
