Installing PSP 1000 LCD Screen
User-Contributed Guide
  • Author: Henry Lee
  • Time required: 20 minutes
  • Difficulty: Moderate
  • Add Note x
  • x 26
This guide will help you replace the LCD screen if it has been cracked or damaged.
Image #1
  • Turn the PSP over so its back is facing you.
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Locate the battery casing button on the rear-left side of the PSP.
  • Press down the button and remove the battery cover.
Image #1 Image #2
Add Note Edit Step 3  ¶
  • Using your finger, remove the battery upwards from the system as shown.
Image #1 Image #2
Add Note Edit Step 4 — Front Casing  ¶
  • Remove the 4 screws, with a phillips #00 screwdriver, shown. (one screw not highlighted is in lower left corner)
  • you will have to remove the Guarantee sticker to unscrew the hidden screw.
Image #1
Add Note Edit Step 5  ¶
  • Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
  • Remove screws from back righthand side within the holes.
Image #1 Image #2
Add Note Edit Step 6  ¶
  • Gently separate the outer plastic casing from the rest of the system as shown.
Image #1
Add Note Edit Step 7 — LCD Screen  ¶
  • The Button Board, at the base of the LCD Screen, is held by two clips.
  • Pry these clips over the nubs using a PSP opening tool. This will release the clips.
  • The Button Board is still attatched to the PSP by a ribbon cable!
Image #1 Image #2 Image #3
Add Note Edit Step 8  ¶
  • The Button Board Ribbon Cable is held down with a latch. Lift the latch open, away from the ribbon cable.
  • Pull the cable away from the latch.
Next » « Previous
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
54 Bit Driver Kit
$24.95 · 50+ In stock
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 17 In stock
Portable Anti-Static Mat
$24.95 · 10 In stock
Popular Products
Unibody Laptop Dual Drive
$39.95 · 3 In stock
iPhone 4S Rear Glass Panel
$44.95 · 50+ In stock
iPhone 4S Replacement Battery
$29.95 · 10 In stock
Plastic Opening Tools
$2.95 · 50+ In stock
T8 Torx Security Bit Screwdriver
$6.95 · 43 In stock
