Installing PSP 1000 Buttons
User-Contributed Guide
  • Author: Henry Lee
  • Time required: 15 minutes
  • Difficulty: Easy
  • Add Note x
  • x 6
The PSP's buttons may become jammed or may not function properly. This guide will show how to access the buttons for repair, cleaning, or replacement.
Image #1
  • Turn the PSP over so its back is facing you.
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Locate the battery casing button on the rear-left side of the PSP.
  • Press down the button and remove the battery cover.
Image #1 Image #2
Add Note Edit Step 3  ¶
  • Using your finger, remove the battery upwards from the system as shown.
Image #1 Image #2
Add Note Edit Step 4 — Front Casing  ¶
  • Remove the 4 screws, with a phillips #00 screwdriver, shown. (one screw not highlighted is in lower left corner)
  • you will have to remove the Guarantee sticker to unscrew the hidden screw.
Image #1
Add Note Edit Step 5  ¶
  • Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
  • Remove screws from back righthand side within the holes.
Image #1 Image #2
Add Note Edit Step 6  ¶
  • Gently separate the outer plastic casing from the rest of the system as shown.
Image #1 Image #2 Image #3
Add Note Edit Step 7 — Buttons  ¶
  • If the Arrow Buttons are not functioning properly, flip over the outer casing and locate the inside of the buttons, as shown
  • Carefully remove the black rubber backing off of the buttons.
  • Clean the inside of the rubber and the outside of the buttons with a cloth.
Image #1 Image #2
Add Note Edit Step 8  ¶
  • If needed, replace the old buttons with a new set (which can be purchased from Sony or other electronics stores).
  • Carefully re-insert the buttons. This should not require excess force, as the buttons should fit if they are arranged correctly.
  • Gently re-apply the back rubber to the back of the buttons.
Next » « Previous
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 11 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
Popular Products
iPhone 3GS Replacement Battery
$19.95 · 50+ In stock
Soldering Station
$24.95 · 12 In stock
Screw Extracting Pliers
iFixit Epic Screwdriver Set
$40.95 · 50+ In stock
iOpener
$14.95 · 50+ In stock
