Introduction
Well repairing phones can sometimes be an easier task or sometimes quite a difficult one. Recently we had a customer request a repair on a Nokia C5-03, naturally I checked ifixit.com, with no luck and without being able to find any other guides, decided to delve in and see what happens overall it isnt too difficult but may require some force in places, so if you arent game to put a bit of presure on it, this guide isnt for you, there may be a better way, but this is how I did, hope it helps someone replace their damaged touch screen.
Wedge the flat end of a plastic opening tool between the front panel assembly retaining clip and the outer case (highlighted in blue).
Carefully pry the opening tool upwards to release the retaining clip securing the upper portion of the front panel assembly.
Run the flat edge of a plastic opening tool around the perimeter of the front panel assembly to release the remaining retaining clips.
Using a heat gun or hairdryer, heat the top area of the front panel assembly for approximately 20 seconds.
Use your fingernails or a plastic opening tool to separate the glass from the front panel assembly. The glass is held to the front panel assembly by adhesive, it may require some work to free it.
10 other people completed this guide.
