Image #1
Add Note Edit Step 9  ¶
  • Use a spudger to pry the Wi-Fi cable off its socket on the underside of the Wi-Fi board.
Image #1
Add Note Edit Step 10 — Motherboard  ¶
  • Use a spudger to pry the microphone cable off the motherboard.
  • Pry from underneath the cable.
Image #1 Image #2
Add Note Edit Step 11  ¶
  • Using the flat end of a spudger, flip up the retaining flap on the camera ribbon ZIF connector.
  • Use the pointed end of a spudger to pull the camera ribbon from the ZIF connector.
Image #1 Image #2
Add Note Edit Step 12  ¶
  • Using the flat end of a spudger, flip up the retaining flap on the touchscreen cable ZIF connector.
  • With the pointed end of the spudger, pull the touchscreen cable from its connector on the motherboard.
Image #1 Image #2
Add Note Edit Step 13  ¶
  • Using the flat end of a spudger, flip up the retaining flap on the backlight cable ZIF connector.
  • With the pointed end of the spudger, pull the backlight cable from its connector on the motherboard.
Image #1 Image #2
Add Note Edit Step 14  ¶
  • Using the flat end of a spudger, flip up the retaining flap on the lower display data cable ZIF connector.
  • With the pointed end of the spudger, pull the lower display data cable from its connector on the motherboard.
Image #1 Image #2
Add Note Edit Step 15  ¶
  • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-Pad/power button cable.
  • With the pointed end of the spudger, pull the D-Pad/power button cable from its connector on the motherboard.
Image #1
Add Note Edit Step 16  ¶
  • Using the flat end of the spudger, pry the battery cable up off its socket on the motherboard.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Related Products
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 17 In stock
Portable Anti-Static Mat
$24.95 · 10 In stock
